While add pin it throw exception "Value does not fall within the expected range"
Although your tag says ArcGIS Desktop.. perhaps you could explain what you are doing that results in that error message.
ArcMap? ArcGIS Pro?
Pin?
Do you have a screen grab? to show what specifically you are referring to?
I am using ArgMap 10.6 version.
I created .mxd with GDB file after load that file from .Net desktop application.
Map loaded but i try to add marker it will throw exception as previously i said.
So your question was branched to a new question but it is marked answered.
You might want to explain the solution a bit though
ArcMap? ArcGIS Pro?
Pin?
