photos in survey123(Feature Service)
1104
5
09-14-2018 06:39 AM
PamelaLandy
I am trying to generate a survey from a FS in survey123 --using 123connect--, my survey requires several photos and the signature. After review, a related table is needed.
When I generate all it from AGOL to my survey (top down)  to understand the construction of the FC table and relationship, I can see that the composite relationship 1 to M between the FC and the table is GlobalID vs. ParentglobalID. I try to recreate the FC and the table in the relation for my FS but the table does not appear.
Someone has been able to carry out a survey of this type (generated from an FS to have more than one photo and signature)
JamesTedrick
Esri Esteemed Contributor
Hi Pamela,
It looks like the relationship is not properly set - you have it going from GLOBALID to GLOBALID - on the pru08 table you need a field named PARENTGLOBALID to receive the value.
PamelaLandy
I generate the relationship between FC and the table, through the globalID field for both the Feature Service is generated, then the survey is created in connect123 but when I try to publish it I find an error of:
Unsupported relationship type esriFieldTypeGlobalID in key field GLOBALID for table GLOBALID
JamesTedrick
Hi Pamela,
Can you provide information on the feature class/table schema and relationship class?
Also, in terms of photo storage, Survey123 makes use of the attachments An overview of the Attachments toolset—Help | ArcGIS Desktop - you do not need to create the tables store images manually.
PamelaLandy
Hi James , thanks for your response, I have a EGDB in ora 12 The feature service is hosted in portal 10.6.
JamesTedrick
Hi Pamela,
PamelaLandy
James Tedrick‌ , Thank's for your help.I needed to have a field named "parentglobalid" and that is of the GUID data type
