I am using Esri.ArcGISRuntime.UWP 100.3.0
When using the SketchEditor - in point selection mode - the displayed symbol will always have a halo around it:.
I assume this is because the selected vertex is always the current point. I tried to remove the white halo by doing the following:
1). SketchEditor.Style.SelectionColor = Color.Transparent. This actually just makes the halo white.
2). SketchEditor.ClearVertexSelection(). This does not seem to do anything in point selection mode. Immediately after calling this, SketchEditor.SelectedVertex is still populated.
When selecting a point, there is no need to have a halo around the selected vertex to differentiate it, so my question is: Is there a way to get rid of the halo?
Here is my symbol for reference:
SketchEditor.Style.SelectedVertexSymbol = new SimpleMarkerSymbol() { Style = SimpleMarkerSymbolStyle.Cross, Color = Color.Transparent, Outline = new SimpleLineSymbol() { Color = Color.Red, Width = 2 }, Size = 20 }
Jeff
Thanks for your feedback, Jeff. It is currently a known issue for dynamic rendering mode to render transparent color as white. Also any of the vertex methods are only applicable to geometries that allow vertex editing (i.e. Polyline, Polygon) that is why you're not seeing this affect SketchCreationMode.Point. You are right updating SelectedVertexSymbol. However, updating the graphic's selection state is internal and for Point, they are always selected.
To workaround this issue, you can do the following
