ImageServiceIdentifyTask doesn't execute
962
6
09-11-2018 01:20 PM
NaciDilekli
I would like to calculate the elevation of each point during an edit session. I am capturing the location of the edited point using the before-apply-edits event. However, I could not get the ImageServiceIdentifyTask to execute (Also tried IdentifyTask in case I was missing something).
I can manually query my imageservice at demImageURL successfully from the ArcGIS REST Services Directory on my server.
I am adding the code. What am I missing? Thanks.
    systemEditor.startup();
    identifyDemTask = new ImageServiceIdentifyTask(demImageURL);
    identifyTask = new IdentifyTask(demImageURL);
    identifyParams = new IdentifyParameters();
    identifyParams.tolerance = 3;
    identifyParams.width = map.width;
    identifyParams.height = map.height;
    systemEditor.templatePicker.on("selection-change", lang.hitch(this, function () {
        var selected = systemEditor.templatePicker.getSelected();
        if (selected) {
            var featureLayer = selected.featureLayer;
            On.once(featureLayer, "before-apply-edits", lang.hitch(this, function (evt) {
                if (evt.adds && evt.adds.length > 0) {
                    var imageParams = new ImageServiceIdentifyParameters();
                    var point = new Point(evt.adds[0].geometry.x, evt.adds[0].geometry.y, evt.adds[0].geometry.spatialReference);
                    imageParams.geometry = point;
                    imageParams.mapExtent = map.extent;
                    identifyParams.geometry = point;
                    identifyParams.mapExtent = map.extent;
                    var deferred = identifyTask
                    .execute(identifyParams)
                    .addCallback(function (response) {
                        // I see nothing here
                        console.log(response);
                    var deferred2 = identifyDemTask
                    .execute(imageParams)
                    if (evt.adds[0].attributes.hasOwnProperty('elevation')) {
                        // to go inside the deferred execution
                    systemEditor.attributeInspector.refresh();
RobertScheitlin__GISP
Naci,
  Here are the changes I would make:
        if (selected) {
                    identifyDemTask.execute(imageParams, function(response) {
                    }, function(err){
                        console.error(err);
Naci,
        if (selected) {
                    }, function(err){
                        console.error(err);
NaciDilekli
Thanks Robert! I am curious though as I followed this example: Display identify results in popup | ArcGIS API for JavaScript 3.25
How come that didn't work?
Naci,
  Because you can not use an IdentifyTask on an Image Service
NaciDilekli
Robert,
Well, I was trying to use the ImageServiceIdentityTask, too.
That didn't execute either. The difference I see is the use of the addCallback method.
I am not sure what was going wrong but I never use .addCallback personally.
NaciDilekli
Noted, thanks!!
