ArcGIS 10.4.1 arcpy - Has Raster Attribute Table been built?
765
09-11-2018 07:58 AM
JoanneMcGraw
Occasional Contributor III
I have an arcpy script that I run in ArcGIS Catalog 10.4.1. The code creates a raster attribute table for a raster; a step which takes a couple of minutes to execute. Subsequent to that step, fields from a feature class are joined to it.
In an effort to make the code faster, I would like to check if the raster attribute table has already been created by a previous run and then check if the fields from the feature class have already been appended so I can skip these two processes. I know how to check the fields, but can't figure out how to find out if the RAT has already been built.
If I ListFields on the raster, it tells me that fields exist whether the RAT has been created or not; I imagine because they exist in memory. However, if I assume the existence of fields indicates the RAT exists, when I try to JoinFields, it fails because the RAT doesn't.
If worse comes to worst, I suppose I can try/except to JoinFields and if it fails because it can't find the table, I can build the RAT and then try JoinFields again. However, I am surprised I can't find a way to determine whether it already exists. ListTables doesn't return a RAT even it if does exist.
Is anyone aware of a method for finding out if a Raster Attribute Table has already been built?
Regards,
jtm
JoanneMcGraw
In case anyone else has the same question, here's what I've come up with...
It appears that when a raster attribute table is created in a file geodatabase, it is given the same name as the raster with "VAT_" pre-pended; e.g., "VAT_rasterName". So, in my code, I am now doing the following to determine if the RAT has already been built (note: path2FeatureClass points to the Feature Class the raster was created with):
   import arcpy
   import os
   path2Fgdb = os.path.dirname(path2Raster)
   ratName = "VAT_" + os.path.basename(path2Raster)
   ratTable = os.path.join(path2Fgdb, ratName)
   if not (arcpy.Exists(ratTable)):
      arcpy.BuildRasterAttributeTable_management (path2Raster, "NONE")
   fields = arcpy.ListFields(path2Raster, "myFieldName")
   if (fields is None or len(fields) < 1):
      arcpy.JoinField_management(path2Raster, "Value", path2FeatureClass, "OBJECTID", "")
Not sure if it's safe to do this (in terms of future support), but for the moment it appears to be doing what I need it to do.
Cheers,
jtm
JoanneMcGraw
   import arcpy
   import os
Cheers,
jtm
