I have successfully used your tools to add GTFS data to a Network Dataset and created a multimodal network (pedestrian path and boat lines). Now my goal is to publish a network service to ArcGIS Server (version 10.5.1) to use it in a mobile application (I use Visual Studio Xamarin with ArcGIS Runtime SDK for .NET 100.3.0). In practice I would like my app to be able to perform a route analysis on the network. Do I have to configure the server in any particular way? Can you give me any suggestions? Thanks in advance
Massimo
(Università Iuav di Venezia - Italy)
Hello Massimo. You have to do a few special things with Server in order to work with a GTFS-enabled network dataset. Please see this section of the user's guide.
What machine will you be using to host the service? You need to install Add GTFS to a Network Dataset on that machine and then follow the additional instructions to "register" TransitEvaluator.dll with ArcGIS Server. ArcGIS Server is usually installed in C:\Program Files.
If the server machine doesn't have ArcMap installed, you won't be able to use the installer to install Add GTFS to a Network Dataset. In that case, I think you can just copy the folder holding TransitEvaluator.dll to the server machine: C:\Program Files (x86)\ArcGIS\Desktop10.[version]\ArcToolbox\Toolboxes\EvaluatorFiles.
