How can i connect my Layer attributes data in real time connectivity with database tables in ArcGIS Pro
455
09-11-2018 03:37 AM
AnkanGhosh
Actually, i am plotting the points on the map with XY coordinates fields from table in database. what i am trying to do is whenever the data is updated on database it should refreshes the data on plotted points too in layer.
Event layer refresh category should have a add functionality to reload updated data from connected databases like SQL Server/Postgre DB if there are changes or updates in database. Currently the functionality to refresh the points and attributes are limited to layers and i am not able to fetch the refresh data from database to Event Layer in real time even after setting the cache & refresh rate in layer.
Any help is appreciable here.
MartyBrett
I can but agree it was a great disappointment to find 2.2 still cant handle the live reading of XY data in a sql table, which is so simple in Map.
