I'm trying to copy a field from a joined table to feature class. This is easily accomplished in ArcMap with the field calculator or in model builder. However, I can't seem to get it working with Python. Any help would be greatly appreciated. Thanks.arcpy.MakeFeatureLayer_management(sde_SDE_nuts0, sde_nuts0_view)
# Process: Join Summary Table to NUTS Poly
arcpy.AddJoin_management(sde_nuts0_view, "NUTS", "sde_SDE_EU_CTY_SUM_view", "Country_Code_NUTS", "KEEP_COMMON")
# Process: Copy PotPUMTotal - PotPUMTotal field already exists
arcpy.CalculateField_management(sde_SDE_nuts0, "PotPUMTotal", "[sde.SDE.EU_CTY_SUM_JSA_Test.SUM_PotPUMTotal]", "VB", "")
It errors with Error #999999?
