Can I set the basemap in the Report(Beta) to my custom base map instead of the esri default?
258
09-10-2018 10:38 AM
NoelPerkins3
New Contributor III
I have set my base map in Survey123 to my custom (tiled) basemap, I would like for the report to also use that same basemap when it generates the report as opposed to the esri default.
JamesTedrick
Esri Esteemed Contributor
Hi Noel,
Yes, you can specify a basemap in the template- refer to the 'Geopoints' section of Print survey results—Survey123 for ArcGIS | ArcGIS
