Install Python Packages through python package manager in arcgis pro
7885
14
09-10-2018 04:58 PM
ManishShrivastav
When I try to install python packages like 'spyder' through the package manager in arcgis pro 2.2.2, it doesn't allow me to do so. The install button is greyed out. Any help?
DanPatterson_Retired
They have seen this thread.  Just no commentary as yet.
You can't....
Conda install is the only route for now
/blogs/dan_patterson/2018/07/01/arcgis-pro-your-conda-environments
Once installed, fluffy it up a bit
/blogs/dan_patterson/2017/07/01/arcgis-pro-2-creating-desktop-shortcuts
Then you will have a great python IDE
/blogs/dan_patterson/2018/01/28/spyder
or this if you don't
ManishShrivastav
Thanks. Seems to be working.
what seems to be working? the solution I provided? or something else?
ManishShrivastav
Yes I created shortcut for the environment as per your suggestion
Nothing in the new release notes on this topic
Release notes for ArcGIS Pro 2.2—ArcGIS Pro | ArcGIS Desktop
any movement??
Kory KramerShaun Walbridge
JoeBorgione
any movement??
I'd like to hear about any movement as well; I've gone ahead and drank to cloning KoolAide, it would be nice to get at least some acknowledgement regarding the situation...
MatthewDriscoll
Any update on this?
