onMouseDownMap event with Line shape - Addin Tool
1588
10
09-07-2018 11:36 AM
YoavAbadi
I'm having issuses while developing a new addin - it seems that ALL mouse event handlers (except onMouseMove[Map]), doesn't work / blocked when I draw a line in on the map.
I really need that functionality, since my tool need to ignore certain points on the polyline, indicated by ctrl+left mouse click.
Does anybody knows how can I get thouse events while drawing a line?
Yoav.
P.S: There's a code example:
class DrawLine(object):
    """Implementation for SomeToolExample.drawline (Tool)"""
    def __init__(self):
        self.enabled = False
        self.shape = "Line"
    def onMouseDown(self, x, y, button, shift):
        # This DOESN'T work (blocked?) while a drawing a line
        pass
    def onMouseDownMap(self, x, y, button, shift):
        pass
    def onMouseUp(self, x, y, button, shift):
        pass
    def onMouseUpMap(self, x, y, button, shift):
        pass
    def onMouseMove(self, x, y, button, shift):
        # This is working while a drawing a line
        pass
    def onMouseMoveMap(self, x, y, button, shift):
        pass
    def onDblClick(self):
        pass
    def onKeyDown(self, keycode, shift):
        pass
    def onKeyUp(self, keycode, shift):
        pass
    def deactivate(self):
        pass
    def onLine(self, line_geometry):
        # Main Logic here, not important for this example
        pass
DanPatterson_Retired
Is this the help topic you are following?
Tool class—Help | ArcGIS Desktop
YoavAbadi
Hi Mark,
Thanks for replying.
What do you mean by following?
I did read all the documentations and every existing post here/gis-stockexcstock before I posted this .
But, i didn't see anywhere a mention about one event blocking the other.
I did see that by using None shape, you can utilize the on events handlers, but as I mentioned above, I must have a line drawing while using them 😕
I you have any idea what to do, it will be much appreciated!
Yoav.
They need some more specific examples I suppose, but the way I read it, nothing will happen and no functions are called until the line is drawn first. There doesn't seem to be any example of drawing a line and skipping points
YoavAbadi
Do you know if there is something like that in arcobjects, in case illI have to rewrite everything in c# for skipping a point?
I want just the coords of the points whike there been drawn 😕
I don't use arcobjects… my preference would be a right-click on a selection rather than trying to skip stuff during a drawing process
YoavAbadi
Yes, but that's what i have to do.. 😕
Thanks, Yoav.
RandyBurton
There is an example of onMouseDownMap on this page:  How To: Capture map coordinates with a mouse click using Python
YoavAbadi
Hi Randy,
Yes, I read that, as you see, this code uses None shape, and i need the mouse events to work while in line shape event.
Do you hace a solution to that?
Yoav.
RandyBurton
What code have you tried with the onMouseDownMap? Just 'pass'? Don't know if something like this would work, but have you tried saving the onMouseDownMap x, y, button and shift data in an array, and then checking the array when onLine is triggered?
