How to calculate multiple equations (a+bX+cY+dZ), where (a, b, and c) are regression coeficients and (X, Y and Z) are rasters, using Pyton?
5687
35
09-03-2018 01:23 PM
LuizVianna
I need to run 252 equations to calculate freeze probability using lat, lon, and altitude as raster inputs, multiplied by a, b, c and d regression coeficients. The equations are in format a+b*lat+c*lon+d*alt.
The equations are in an Excel spreedsheet (attached) and I need to write them in a python script. The lat, lon and lat raster datasets are in the same folder and the output tif files have a standardized name (also in the Excel file).
Thank you!
LuizVianna
Thank you all!
The final code is:
import numpy as np
import arcpy
wksp = "D:\Vianna\Dados\Raster\Clima\ETP"
arcpy.env.workspace = wksp
lat = arcpy.Raster("D:\Vianna\Dados\Raster\Topografia\latit.tif")
lon = arcpy.Raster("D:\Vianna\Dados\Raster\Topografia\longit.tif")
alt = arcpy.Raster("D:\Vianna\Dados\Raster\Topografia\mde_sc_90.tif")
tbl = "D:\Vianna\Dados\Raster\Clima\Raster_Clima.gdb\TB_EQUAC_ETP"
arr = arcpy.da.TableToNumPyArray(tbl, "*")
eqs = arr['DS_EQUAC']
filenames = ["{}{}{}{}".format(*i) for i in arr[['SG_PREFIX', 'SG_SUFIX', 'SG_PERIO', 'SG_FORMA']]]
a = arr['VL_A']
b = arr['VL_B']
c = arr['VL_C']
d = arr['VL_D']
for i in range(len(filenames)):
 print(filenames[i])
 eq = a[i] + b[i] * lat + c[i] * lon + d[i] * alt
 eq.save(filenames[i])
DanPatterson_Retired
It can
import numpy as np
import arcpy
lat = np.arange(50, 40, -1., 'float')
lon = np.arange(-80, -70, 1., 'float')
lon, lat = np.meshgrid(lon, lat)
tbl = r"C:\GIS\testing_project\testing_project.gdb\equations"
eqs = arr['EQ']
fns = ["{}{}{}{}".format(*i) for i in arr[['PROB', 'DEC', 'TMIN', 'FORMAT']]]
a = arr['a']
b = arr['b']
c = arr['c']
arrs = [a[i] + b[i]*lat + c[i]*lon for i in range(len(a))]‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
I have replaced your lon and lat rasters with numpy arrays to demonstrate.  They are formed from a 'meshgrid' using the sample ranges.  They are shown below
The file names are simply put together from your spreadsheet using the ExcelToTable tool in Pro (map has one).
The table was converted to a numpy array (line 7).
You can slice out an equation to check if you want (line 😎
I pieced the bits together to form the file names (line 9)
The constants `a`, `b` `c` are similarly pulled from the array like the other columns
The final results are put together as individual rasters just using a list comprehension (line 13)
Here are some samples
lon  # ---- longitude formed from the meshgrid
array([[-80., -79., -78., -77., -76., -75., -74., -73., -72., -71.],
       [-80., -79., -78., -77., -76., -75., -74., -73., -72., -71.]])
lat  # ---- latitude formed from the meshgrid
array([[50., 50., 50., 50., 50., 50., 50., 50., 50., 50.],
       [49., 49., 49., 49., 49., 49., 49., 49., 49., 49.],
       [48., 48., 48., 48., 48., 48., 48., 48., 48., 48.],
       [47., 47., 47., 47., 47., 47., 47., 47., 47., 47.],
       [46., 46., 46., 46., 46., 46., 46., 46., 46., 46.],
       [45., 45., 45., 45., 45., 45., 45., 45., 45., 45.],
       [44., 44., 44., 44., 44., 44., 44., 44., 44., 44.],
       [43., 43., 43., 43., 43., 43., 43., 43., 43., 43.],
       [42., 42., 42., 42., 42., 42., 42., 42., 42., 42.],
       [41., 41., 41., 41., 41., 41., 41., 41., 41., 41.]])
a[20], b[20], c[20]   # ---- 3 cooefficients  for the 21 record
(151.33584980670224, 0.7443302423314689, 2.698509149397158)
arrs[20]   # ---- the 21st array, indexing from 0
array([[-27.3, -24.6, -21.9, -19.2, -16.5, -13.8, -11.1,  -8.4,  -5.7,  -3. ],
       [-28.1, -25.4, -22.7, -20. , -17.3, -14.6, -11.9,  -9.2,  -6.5,  -3.8],
       [-28.8, -26.1, -23.4, -20.7, -18. , -15.3, -12.6,  -9.9,  -7.2,  -4.5],
       [-29.6, -26.9, -24.2, -21.5, -18.8, -16.1, -13.4, -10.7,  -8. ,  -5.3],
       [-30.3, -27.6, -24.9, -22.2, -19.5, -16.8, -14.1, -11.4,  -8.7,  -6. ],
       [-31.1, -28.4, -25.7, -23. , -20.3, -17.6, -14.9, -12.2,  -9.5,  -6.8],
       [-31.8, -29.1, -26.4, -23.7, -21. , -18.3, -15.6, -12.9, -10.2,  -7.5],
       [-32.5, -29.8, -27.1, -24.4, -21.7, -19. , -16.3, -13.6, -11. ,  -8.3],
       [-33.3, -30.6, -27.9, -25.2, -22.5, -19.8, -17.1, -14.4, -11.7,  -9. ],
       [-34. , -31.3, -28.6, -25.9, -23.2, -20.5, -17.8, -15.1, -12.4,  -9.7]])
# ---- get the lower left corner from the input lon/lat arrays and make it a point object
LL = arcpy.Point(lon[0,0], lat[-1,0])  # magical slicing
outname = "C:\\Temp\\{}".format(fns[20])
outname
'C:\\Temp\\pgead21n3.tif'
outraster = arcpy.NumPyArrayToRaster(arrs[20], LL, 1., 1.)  # last 2 terms are cell size
outraster.save(outname)‍‍‍‍‍‍‍‍‍‍‍‍
I missed some of the remaining terms, but you get the drift I am sure I have attached the raster as a *.tif
LuizVianna
This is what I need:
Follow a data sample.
import arcpy
env.workspace = r"D:\Vianna\Dados\Raster\Clima" #Folder with raster datasets. This line is not working...
#Input raster datasets of the same masked area and same spatial reference
lat = r"D:\Vianna\Dados\Raster\Topografia\latit.tif" #Input lat raster
lon = r"D:\Vianna\Dados\Raster\Topografia\longit.tif" #Input lon raster
alt = r"D:\Vianna\Dados\Raster\Topografia\mde_sc_90.tif" # Input dem raster
tbl = r"D:\Vianna\Dados\Raster\Clima\Raster_Clima.gdb\TB_EQUAC_ETP"
arr = arcpy.da.TableToNumPyArray(tbl, "*")#This line close the ArcGis Pro
fns = ["{}{}{}{}".format(*i) for i in arr[['SG_PREFIX', 'SG_SUFIX', 'SG_PERIO', 'SG_FORMA']]]
a = arr['VL_A']
b = arr['VL_B']
c = arr['VL_C']
d = arr['VL_D']
eq = [a[i] + b[i]*lat + c[i]*lon + d[i]*alt for i in range(len(a))] #This is the equation I need
#How to run this equation and write outputs named as "fns"?‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
DarrenWiens2
MVP Honored Contributor
Try running it in a loop (untested):
for item in arr:
  fn = "{}{}{}{}".format(
    item['SG_PREFIX'],
    item['SG_SUFIX'],
    item['SG_PERIO'],
    item['SG_FORMA']
  a = item['VL_A']
  b = item['VL_B']
  c = item['VL_C']
  d = item['VL_D']
  eq = a + b*lat + c*lon + d*alt
  ... output here
LuizVianna
The line below closes the  ArcGisPro
I made a geodatabase table from the excel file and used it in your line 12
LuizVianna
I also did it. And the table is in the file geodatabase. However when I run the line 14, the Python crashes. I´ve tried to run from ArcGis Pro and from prompt.
Did you try to run the script with attached data?
I dont know if the problem is in the script or is the file geodatabase.
line 6....  tbl = r"C:\GIS\testing_project\testing_project.gdb\equations
I converted your excel to a geodatabase table
I used the code in my example (which you would have to add an extra parameter to I think)
It was for demonstration purposes, but it works
LuizVianna
I thank you all, but unfortunatly it still doesn´t working here. I follwed the code step by step, I re-imported the excel table to geodatabase and the line "arr = arcpy.da.TableToNumPyArray(tbl, "*")" still closing Python.
import numpy as np
import arcpy
lat = np.arange(-29.373511, -25.928348, 0.000871310821466946, 'float')
lat
array([-29.373511  , -29.37263969, -29.37176838, ..., -25.93009063,
       -25.92921932, -25.92834801])
lon = np.arange(-53.915588, -48.273851, 0.000871310821466947, 'float')
lon
array([-53.915588  , -53.91471669, -53.91384538, ..., -48.27646436,
       -48.27559305, -48.27472174])
lat
array([[-29.373511  , -29.373511  , -29.373511  , ..., -29.373511  ,
        -29.373511  , -29.373511  ],
       [-29.37263969, -29.37263969, -29.37263969, ..., -29.37263969,
        -29.37263969, -29.37263969],
       [-29.37176838, -29.37176838, -29.37176838, ..., -29.37176838,
        -29.37176838, -29.37176838],
       [-25.93009063, -25.93009063, -25.93009063, ..., -25.93009063,
        -25.93009063, -25.93009063],
       [-25.92921932, -25.92921932, -25.92921932, ..., -25.92921932,
        -25.92921932, -25.92921932],
       [-25.92834801, -25.92834801, -25.92834801, ..., -25.92834801,
        -25.92834801, -25.92834801]])
lon
array([[-53.915588  , -53.91471669, -53.91384538, ..., -48.27646436,
        -48.27559305, -48.27472174],
        -48.27559305, -48.27472174]])
alt
'D:\\Vianna\\Dados\\Raster\\Topografia\\mde_sc_90.tif'
tbl
'D:\\Vianna\\Dados\\Raster\\Clima\\Raster_Clima.gdb\\TB_EQUAC_ETP'‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
a = arr['VL_A']
b = arr['VL_B']
c = arr['VL_C']
d = arr['VL_D']
arrs = [a[i] + b[i]*lat + c[i]*lon + d[i]*alt for i in range(len(a))]
outname = "D:\\Temp\\{}".format(fns[2])
outraster = arcpy.NumPyArrayToRaster(arrs[2], LL, 1., 1.)  # last 2 terms are cell size
import arcpy
arr.dtype
dtype([('OBJECTID', '<i4'), ('PROB', '<U255'), ('DEC', '<U255'),
 ('TMIN', '<U255'), ('FORMAT', '<U255'), ('a', '<f8'), ('b', '<f8'), ('lat', '<U255'),
 ('c', '<f8'), ('lon', '<U255'), ('d', '<f8'), ('alt', '<U255'), ('EQ', '<U255')])
Just to confirm it works.
Which leaves something wrong with your installation.  You are using ArcGIS Pro's arcpy python (3.6 ish).
Do you see this as well?
If not, something is wrong with your file and/or the location of the file ie its path... (spaces? on a network, some symlink?)
dir(arcpy.da)
Out[15]: ['Describe', 'Domain', 'Editor', 'ExtendTable', 'FeatureClassToNumPyArray',
 'InsertCursor', 'ListDomains', 'ListFieldConflictFilters', 'ListReplicas',
 'ListSubtypes', 'ListVersions', 'NumPyArrayToFeatureClass', 'NumPyArrayToTable',
 'Replica', 'SearchCursor', 'TableToNumPyArray', 'UpdateCursor', 'Version', 'Walk',
 '__all__', '__builtins__', '__cached__', '__doc__', '__file__', '__loader__',
 '__name__', '__package__', '__spec__', '_internal_eq', '_internal_sd', '_internal_vb']
Nothing suggested seems to have helped, so I would contact tech support
