I have problem while update configuration for update identity store ArcGIS Portal . Actually that error occures when im using LDAP or Windows authentication. Please help
Error
com.esri.arcgis.portal.admin.core.PortalException: com.esri.arcgis.portal.admin.core.PortalException: java.lang.RuntimeException: java.lang.Exception: Server returned HTTP status code 301. Requested URL: https://GRSP23WSAPX34.FMI.COM:7443/arcgis/sharing/rest/portals/clearCache
Code: 500
Have you set a privatePortalURL? What's the machine name listed under portaladmin/machines? What URL are you using to reach Portaladmin when configuring the identity store?
