AnsweredAssumed Answered
MultipleDefine error while loading the modules from ArcGIS javascript API
Question asked by amol.khalipe@infosys.com on Aug 31, 2018
I have a page where I am loading jQuery using <script> tag. I also have another custom JS file referenced using <script> tag following jQuery <script> tag. My page also references other JavaScript libraries like - momentJS, jQuery.i18n
In custom JS file, I am loading ArcGIS 4.8 JavaScript API using $.getScript() function inside the callback function of $.getScript(), I am loading ArcGIS modules as below.
HTML script references -
<script >
//<![CDATA[
</script>
</script>
<script >
//<![CDATA[
</script>
customJS.js file -
var dojoConfig =
         async:true,
         deps:["jquery"],
         packages: [{
         main: "jquery-2.1.4.min"
         main: "dojo"
$.getScript("https://js.arcgis.com/4.8/", function () {
require([
"esri/Map",
"esri/views/MapView",
"esri/Graphic",
"esri/geometry/Point",
"esri/symbols/PictureMarkerSymbol",
"esri/geometry/Extent",
"esri/config",
"dojo/domReady!"
], function (Map, MapView, Graphic, Point, PictureMarkerSymbol, Extent, esriConfig) {
          var map = new Map({
                  basemap: "streets"
         var view = new MapView({
                  container: "map",
                  map: map,
                  zoom:2
When I try to load my page, it throws an error 'multipleDefine' in dojo.js.
The variable dojoConfig declared and initialized to resolve any loading conflicts but it didn't resolve the error. If I remove this variable, it throws the same error. The error screen shot is attached.
I have not previously worked on AMD and I am sure I am doing something wrong. Can anyone help me fix this problem or provide any directions or documentation ? Any help or direction is appreciated.
Outcomes
