AnsweredAssumed Answered
Measured hatches along line/curve - error/bug in Pro?
Question asked by pal.herman.sund@geodata.no_Geodata on Aug 31, 2018
Latest reply on Feb 18, 2019 by pal.herman.sund@geodata.no_Geodata
I am working with linear measurements along a series of alignments from a tram-operator. The alignments typically has segments of line-curve-line-curve... I am having a struggle with measured hatches along curve elements and wonders if anyone has seen similar, seems Pro does not treat the curves correct:
Test:
- draw (edit) a curve, close to connecting to a circle
- In my case the curve is nearly 100 meter long
As my client has alignments which not always starts at 0, two fields are added:
- Start + Stop. In this case enter values 0 for Start and 100 for Stop
- Use "Create Route" tool, with "Measure Source" set to "Values from two fields" which are set to the Start and Stop attributes
Then I follow the  "Draw measured hatches along lines" recipe (Draw measured hatches along lines—ArcGIS Pro | ArcGIS Desktop ) and enables "allow symbol property connections", which makes it possible to use Arcade "$measure" to get stationing along my route (in Pro terms: at measured units).
The result is a bit strange  Is this a bug or am I doing something wrong?
Attached the described example and a real route as well.
Pål Herman
Outcomes
