Do edits to a Survey123 form reflect in existing data in the feature layer?
374
08-30-2018 10:25 AM
by Anonymous User
Not applicable
I've updated a list of choices within Survey123. This edit is reflected in the form, however, the valid values in the feature layer do not reflect the choices provided in the Survey123 form. For example, I have a data line that was given an incorrect ID. I am trying to edit this data line in ArcGIS Pro, however the list of values does not include the newly updated list. It only gives me to option to pick from the old list of choices. It also does not let me write in a value. All other changes made to the Survey123 form (such as schema changes) since my last edit are showing as expected.
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Vivi,
Survey123 Connect does not update the domain when the choice list is updated.  You will need to update the choice list in ArcGIS Online, which can be done through the item's Data page (Fields tab).
by Anonymous User
Not applicable
Thanks for your response, James. Would it be possible to delete the existing list and upload a new list, or would I have to go through each choice entry individually to make the changes?
JamesTedrick
Hi Vivi,
It's currently an individual add/remove/update process.
