Without a major change to an existing survey, after text edit cannot be published "The file exceeds the max. size 1,000KB"
780
6
08-29-2018 01:57 PM
Josef_Strobl
and, when revising the change, this error persists.
JamesTedrick
Esri Esteemed Contributor
Hi Josef,
I'm unsure about what error you are experiencing.  Is this happening on an attempt to submit a survey record with Survey123?  Republishing a form with Survey123 Connect?
Josef_Strobl
Thanks for getting back to me! No records have been submitted yet, I was attempting to re-publish the survey after a minor edit (browser version, not Connect).
Josef
Von: James Tedrick <geonet@esri.com>
Gesendet: Donnerstag, 30. August 2018 01:11
An: Strobl Josef <Josef.Strobl@sbg.ac.at>
Betreff: Re: - Re: Without a major change to an existing survey, after text edit cannot be published "The file exceeds the max. size 1,000KB"
GeoNet <https://community.esri.com/?et=watches.email.thread>
reply from James Tedrick<https://community.esri.com/people/JTedrick-esristaff?et=watches.email.thread> in Survey123 for ArcGIS - View the full discussion<https://community.esri.com/message/795809-re-without-a-major-change-to-an-existing-survey-after-text-edit-cannot-be-published-the-file-exceeds-the-max-size-1000kb?commentID=795809&et=watches.email.thread#comment-795809>
ZhifangWang
For the web designer, the error message should occur when there's a hosted online image referenced in your survey is larger than 1 MB, such as in survey header/description or note question.
Can you please check the file size for each image you referenced in the survey? Just remove or replace those images with a smaller one (< 1MB) could fix the issue.
Josef_Strobl
Thanks! I have already removed all images, unfortunately the error persists (even when copying the entire survey)
Regards, js
Von: Zhifang Wang <geonet@esri.com>
Gesendet: Donnerstag, 30. August 2018 19:33
reply from Zhifang Wang<https://community.esri.com/people/ZWang-esristaff?et=watches.email.thread> in Survey123 for ArcGIS - View the full discussion<https://community.esri.com/message/795978-re-without-a-major-change-to-an-existing-survey-after-text-edit-cannot-be-published-the-file-exceeds-the-max-size-1000kb?commentID=795978&et=watches.email.thread#comment-795978>
ZhifangWang
Hi Josef,
Can you please make sure there's no visual image you can see before publish? After checking and trying publish again, if the issue still exists, please send us the JSON string of the publish request in the network panel of the browser (shown as below), so we can investigate the issue further. Thanks.
Josef_Strobl
I had deleted the only graphic in the survey with no effect. After deleting the entire survey description (which had contained the graphic) things are resolved now.
Thank you!! josef
Gesendet: Freitag, 31. August 2018 05:30
reply from Zhifang Wang<https://community.esri.com/people/ZWang-esristaff?et=watches.email.thread> in Survey123 for ArcGIS - View the full discussion<https://community.esri.com/message/796104-re-without-a-major-change-to-an-existing-survey-after-text-edit-cannot-be-published-the-file-exceeds-the-max-size-1000kb?commentID=796104&et=watches.email.thread#comment-796104>
