AnsweredAssumed Answered
How to Add Animation to ArcGIS JavaScript API Cluster Layer Breaks
Question asked by BEHSEINI on Aug 29, 2018
Can you please take a look at this demo snippet and let me know how I can add animation to cluster breaks on zoom in out?
As you can see in the demo cluster symbols disappear on zoom in, out and re rendered after zoom stops but how we can add animation to clusters
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8">
    <title>Cluster</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.25/dijit/themes/tundra/tundra.css">
    <link rel="stylesheet" href="https://js.arcgis.com/3.25/esri/css/esri.css">
    <style>
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
      #map{ margin: 0; padding: 0; }
      /* center the image in the popup */
      .esriViewPopup .gallery { margin: 0 auto !important; }
    </style>
    <script>
      // helpful for understanding dojoConfig.packages vs. dojoConfig.paths:
      // http://www.sitepen.com/blog/2013/06/20/dojo-faq-what-is-the-difference-packages-vs-paths-vs-aliases/
      var dojoConfig = {
        paths: {
          extras: location.pathname.replace(/\/[^/]+$/, "") + "/extras"
    </script>
    <script src="https://js.arcgis.com/3.25/"></script>
    <script>
      var map;
      require([
        "dojo/parser",
        "dojo/ready",
        "dojo/_base/array",
        "esri/Color",
        "dojo/dom-style",
        "dojo/query",
        "esri/map",
        "esri/request",
        "esri/graphic",
        "esri/geometry/Extent",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleFillSymbol",
        "esri/symbols/PictureMarkerSymbol",
        "esri/renderers/ClassBreaksRenderer",
        "esri/layers/GraphicsLayer",
        "esri/SpatialReference",
        "esri/dijit/PopupTemplate",
        "esri/geometry/Point",
        "esri/geometry/webMercatorUtils",
        "extras/ClusterLayer",
        "dijit/layout/BorderContainer",
        "dijit/layout/ContentPane",
        "dojo/domReady!"
      ], function(
        parser, ready, arrayUtils, Color, domStyle, query,
        Map, esriRequest, Graphic, Extent,
        SimpleMarkerSymbol, SimpleFillSymbol, PictureMarkerSymbol, ClassBreaksRenderer,
        GraphicsLayer, SpatialReference, PopupTemplate, Point, webMercatorUtils,
        ClusterLayer
        ready(function() {
          parser.parse();
          var clusterLayer;
          var popupOptions = {
            "markerSymbol": new SimpleMarkerSymbol("circle", 20, null, new Color([0, 0, 0, 0.25])),
            "marginLeft": "20",
            "marginTop": "20"
          map = new Map("map", {
            basemap: "oceans",
            center: [-117.789, 33.543],
            zoom: 13
          map.on("load", function() {
            // hide the popup's ZoomTo link as it doesn't make sense for cluster features
            domStyle.set(query("a.action.zoomTo")[0], "display", "none");
            // get the latest 1000 photos from instagram/laguna beach
            var photos = esriRequest({
              url: "data/1000-photos.json",
              handleAs: "json"
            photos.then(addClusters, error);
          function addClusters(resp) {
            var photoInfo = {};
            var wgs = new SpatialReference({
              "wkid": 4326
            photoInfo.data = arrayUtils.map(resp, function(p) {
              var latlng = new  Point(parseFloat(p.lng), parseFloat(p.lat), wgs);
              var webMercator = webMercatorUtils.geographicToWebMercator(latlng);
              var attributes = {
                "Caption": p.caption,
                "Name": p.full_name,
                "Image": p.image,
                "Link": p.link
              return {
                "x": webMercator.x,
                "y": webMercator.y,
                "attributes": attributes
            // popupTemplate to work with attributes specific to this dataset
            var popupTemplate = new PopupTemplate({
              "title": "",
              "fieldInfos": [{
                "fieldName": "Caption",
                visible: true
                "fieldName": "Name",
                "label": "By",
                visible: true
                "fieldName": "Link",
                "label": "On Instagram",
                visible: true
            // cluster layer that uses OpenLayers style clustering
            clusterLayer = new ClusterLayer({
              "data": photoInfo.data,
              "distance": 100,
              "id": "clusters",
              "labelColor": "#fff",
              "labelOffset": 10,
              "resolution": map.extent.getWidth() / map.width,
              "singleColor": "#888",
              "singleTemplate": popupTemplate
            var defaultSym = new SimpleMarkerSymbol().setSize(4);
            var renderer = new ClassBreaksRenderer(defaultSym, "clusterCount");
            var picBaseUrl = "https://static.arcgis.com/images/Symbols/Shapes/";
            var blue = new PictureMarkerSymbol(picBaseUrl + "BluePin1LargeB.png", 32, 32).setOffset(0, 15);
            var green = new PictureMarkerSymbol(picBaseUrl + "GreenPin1LargeB.png", 64, 64).setOffset(0, 15);
            var red = new PictureMarkerSymbol(picBaseUrl + "RedPin1LargeB.png", 72, 72).setOffset(0, 15);
            renderer.addBreak(0, 2, blue);
            renderer.addBreak(2, 200, green);
            renderer.addBreak(200, 1001, red);
            clusterLayer.setRenderer(renderer);
            map.addLayer(clusterLayer);
            // close the info window when the map is clicked
            map.on("click", cleanUp);
            // close the info window when esc is pressed
            map.on("key-down", function(e) {
              if (e.keyCode === 27) {
                cleanUp();
          function cleanUp() {
            map.infoWindow.hide();
            clusterLayer.clearSingles();
          function error(err) {
            console.log("something failed: ", err);
          // show cluster extents...
          // never called directly but useful from the console
          window.showExtents = function() {
            var extents = map.getLayer("clusterExtents");
            if ( extents ) {
              map.removeLayer(extents);
            extents = new GraphicsLayer({ id: "clusterExtents" });
            var sym = new SimpleFillSymbol().setColor(new Color([205, 193, 197, 0.5]));
            arrayUtils.forEach(clusterLayer._clusters, function(c, idx) {
              var e = c.attributes.extent;
              extents.add(new Graphic(new Extent(e[0], e[1], e[2], e[3], map.spatialReference), sym));
            }, this);
            map.addLayer(extents, 0);
    </script>
  </head>
  <body>
    <div data-dojo-type="dijit/layout/BorderContainer"
         data-dojo-props="design:'headline',gutters:false"
         style="width: 100%; height: 100%; margin: 0;">
      <div id="map"
           data-dojo-type="dijit/layout/ContentPane"
           data-dojo-props="region:'center'">
      </div>
    </div>
  </body>
</html>
Outcomes
