Different lat and long for same address
2459
12
08-29-2018 08:44 AM
Stella-MarisAgu
New Contributor III
I Geocoded a list of address (Mostly intersections) for bus routing and the same address was geocoded by a different company. The lat and long values that I get is different from the one from the company. I calculated the difference in excel as shown below. Some seem too big. My question is how much is too big? (Calculation in metres). Looking at the table and map it seems not too far off but when I measure the distances in a straight line it seems much as shown in the table. I used projected coordinate system. I am trying to decide which of the coordinates(Lat/long) is the more precise and accurate so the bus will not miss a student. Is it okay to get varying lat and long for same address? Please can anyone help? Any help with geocoding intersections will be appreciated. I checked the match with no house number to Yes.
Thank you
Tags (1)
JoeBorgione
You mention that you geocoded a list of addresses.  What data did you match against?  Is it your own?  Is it from a reputable source?
If you add the company address points to the street data you'll use to create your network dataset, what sort of precision do they have compared to your points? That is, which points fall in the intersections as they should?
Stella-MarisAgu
New Contributor III
I used the City's street network data to create my reference data before geocoding. I am not sure which data the company used. Could this be a factor in the difference. Is the difference too much to neglect?
Stella-MarisAgu
New Contributor III
Also the points are close most of the time just not on top of each other until you zoom out. I am just curious why they don't match very closely.Thanks for replying me very fast. I appreciate
DanPatterson_Retired
What is the difference between expectation and observation?  A meter?, a couple? 10, 20, 50?.
big differences could be due to errors in coordinate systems and/or projections.  smaller differences could be attributed to precision and accuracy
Stella-MarisAgu
New Contributor III
MeterDifferenceArcGisCoords_For_GoogleGeoFrom_trapeze
552.722454453.4608055278, -113.3776270953.460658, -113.385945
550.10907553.4605877774, -113.38596134653.460739, -113.377683
300.436270653.4285407575, -113.5365383853.430043, -113.532783
299.502530753.626076525, -113.53332615653.624516, -113.537014
Thanks Dan for your reply
I sorted the coordinates and above is the ones with the most difference. The difference is in metres.  I am trying to figure out if I should exclude/ re-geocode those with the big difference like 552 metres. Thank you
if the rest are much smaller, then one or the other is in error... buildings don't move unless they are on wheels.  I would do the google thing and check the points to see the the long/lats look plausible.  Perhaps one of the two points is in a field or a lake or something obvious, indicating an error in geocoding or the collected data
Stella-MarisAgu
New Contributor III
Thanks Dan. I think the difference maybe due to different reference data used. On checking through I realized the high numbers are not 100 % match hence the big difference. My question is does different reference data produce different lat and long for intersections and buildings, in the case where it goes with one side of the intersection versus the other side(L/R) OR a pin on the building roof versus parking lot or back door.
JoeBorgione
Varying results of geocoding against two different data sources in not a surprise to me.  In my original reply I mentioned 'reputable data source'.  That's a key element to geocoding.
Stella-MarisAgu
New Contributor III
Much thanks for clarifying Joe!
