what to do if feature service work with only version 4.7 ?
1711
14
08-28-2018 02:42 PM
Rocky_
I am using few urls as feature layers for graphical representation..but when I tried to use 4.8 ArcGIS JS version it gives me error..
works fine with 4.7..
What to do to work same urls in 4.8 vs of ArcGIS JS...
Any suggestion..
Thanks a lot..
RobertScheitlin__GISP
Your fix to this would be quit using Chrome Web Server extension and start using your machines IIS and the machine name in the url. Then you will not have any issue.
Raj,
   Are you using localhost or file in the url? If so that is the issue i 4.8 you have to use your machine name in the url when developing
What is the url that you are using to develop your app?
Rocky_
yes I am using localhost.
Raj,
  No, not the url of a service you are using but the url that you have in your browser to run your app.
Rocky_
when am trying to do spatial filter it shows me these errors..
Failed to load resource: net::ERR_CERT_AUTHORITY_INVALID
[esri.layers.FeatureLayer] #load() Failed to load layer
Promise rejected: Error loading
Promise rejected: esri/config: esriConfig.request.proxyUrl is not set. If making a request to a CORS-enabled
server, please push the domain into esriConfig.request.corsEnabledServers.
OK, but you understanding my question about the url you are using when accessing your developed application likely has a large impact on that error. So when I am developing on my laptop I have my html files in a certain directory (say c:/JSWorkspace) and that folder in setup as a virtual folder in IIS so that I can access it using a url like http://gislap183/js/ in my web browser. So if I am working on testing.html then the url I use to debug and run my app is http://gislap183/js/testing.html. Now if you are using file:///C:JSWorkspace/testing.html in your browsers url then that is what I mean by file system url. If you are using http://localhost/js/testing.html that that is what I mean by localhost. Neither of those urls will working in JS API 4.8 properly.
Rocky_
I totally understand that. .
I am using Web Server for Chrome extension to run program..
but I think web service need some modifications..
its not properly working in 4.8..only works with 4.7
RAJ,
   I have no experience using Web Server for Chrome extension. But it is likely running into the same issue that 4.8 does when you use localhost or file based urls. Does your machine not have IIS installed?
Rocky_
No, don't have IIS... can you tell me one thing. even the feature layer is not working with 4.8... only working with 4.7 JS...
Is there any possiblity to use the same url with 4.8..
Or need to update service itself..
