AnsweredAssumed Answered
Access arcpy on Linux
Question asked by wqs@binghamton.edu on Aug 28, 2018
Latest reply on Aug 31, 2018 by SWalbridge-esristaff
I have installed ArcGIS Server 10.6.1 on Linux and followed the instruction here to create a conda environment named arcgis with Python 3.6. Using the shell, I can activate the conda env and import arcpy successfully. However, the conda env does not work with any IDE (e.g., PyCharm, VS Code) or Jupyter Notebook. See below the message I got when trying to import arcpy in Jupyter Notebook. Any help will be greatly appreciated!
error                                     Traceback (most recent call last)
<ipython-input-1-5467a3dc9fe3> in <module>()
----> 1 import arcpy
/opt/anaconda/envs/arcgis/lib/python3.6/site-packages/arcpy/__init__.py in <module>()
68
         raise ImportError("arcpy needs to run within an active ArcGIS Conda environment")
69
else:--->
70
     import _initagsenv
71
72
from arcpy.geoprocessing import gp
error: WSLib: failed initializing arcpy. Check if environment was activated correctly.
arcpy only works in Console
arcpy-linux
Outcomes
