USA Mean Temperature layer Celsius to Fahrenheit?
1092
5
08-27-2018 11:00 AM
FrancisHourigan1
Does anyone know how to take the USA Mean Temperature layer and display the temp in Fahrenheit instead of Celsius? I tried to do a custom configuration of the pop-up window as follows: Mean Temperature: {Raster.ItemPixelValue*1.8+32}°F However, it did not work... Thanks!
XanderBakker
Esri Esteemed Contributor
It seems that there is no support for Arcade expressions in the pop-up configuration of the image service layer. Would be a great addition (so please create an idea here: ArcGIS Ideas and I will certainly give it my vote!)
Working with raster data is a bit different than working with vector data. See this example below in London (temperature is expressed in °C):
For the symbology you can create a simple Arcade expression as you showed:
This will allow us to view the legend in °F:
For the pop-up you need to create the expression:
... and then reference it in the pop-up configuration (sorry for the Spanish interfaces):
As a result the information will display in °F:
Unfortunately, this is not available for the tiled service you want to use.
CC Kelly Gerrow‌, is this in the product plan?
KellyGerrow
Esri Frequent Contributor
Hi Xander,
This is something that is currently being evaluated by the development team. Please log an Idea and share your use cases so we can incorporate them into the discussion.
Katie Cullen
FrancisHourigan1
I created the Idea...
KellyGerrow
Here is a link to the idea for others to promote:
https://community.esri.com/ideas/15509
XanderBakker
Hi Francis Hourigan , don't forget to upvote your own idea
