Is there a way I could create a network dataset from shapefile or features in ArcGIS Pro?
I do have the Network Analyst license but it seems the options that are on many examples in Arc Map are not showing in Pro.
Cheers,
Benjie
Cheers,
Benjie
The existing tools are here
An overview of the Analysis toolset—ArcGIS Pro | ArcGIS Desktop
Do you have a template dataset?
It wasn't available in pro 2.1, but I can't find any reference as to whether it is now.
But if you have arcmap, create the network there, then you can use it
Thanks Dan. Unfortunately I don't have ArcMap. I downloaded the tutorial to get an existing network dataset and create a template from it. Unfortunately, it seems that the schema will not fit the data that I currently have - the table structure is a bit complex for the route analysis I want to carry out.
You cannot yet create a new network dataset as of ArcGIS Pro 2.2. We are working toward adding this capability, but it is not yet complete. You still have to use ArcMap to create network datasets unless you're using the Create Network Dataset From Template geoprocessing tool.
