I want to create a lithology chart for every points (borehole) on map. I've tried using ArcGIS Pro's pops up chart, but there's a lot of problems and limitations? (Please advise if I am wrong, I will post the issue in another group)
Then, I turn to Related Table Charts widget as the data are to be published on ArcGIS Portal. But in the widget configuration, I can't select a table related to layer (See image). I thought maybe widget doesn't accept widget with non-numeric fields (indicated below), so I deleted all the non-numeric fields. But still the same, can't select a table.
I've created the layer in ArcGIS Pro by relating the two dataset.
I want to create something like this.
My data (Borehole ID as Primary key)
Left: Type: Table Right: Feature class
Please advice if there's any alternatives other than this widget.
Johana
If you check your service in ArcGIS Server, do you see below 'query related records'?
Did you ever find a resolution to this issue? I'm encountering the same problem. I have setup relationships in both the service and at the geodatabase level. The map is being created in ArcGIS Pro. Maybe I need to create the service in desktop?
I solved this doing the following:
