Open LDockable panel
783
08-16-2018 10:29 AM
James_001
Occasional Contributor II
Hello fellows,
I am trying to open LDockable panel in my Jewelry box theme,I want to open on button click function from my other widget. I am using WAB Dev Edt 2.7. By default my LDockable panel is closed.Here is the function, which i tried so far.
_showFoldablePanel: function (){
            var pm =PanelManager.getInstance();
            pm.openPanel(this.appConfig.widgetPool.panel[0]);
Irfan Afsar
RobertScheitlin__GISP
Irfan,
   So here is what you will need to add to your widget that is attempting to open the LDockable Panel.
1. Add these defines
define([
'jimu/WidgetManager',
'jimu/PanelManager',
'dojo/_base/array'
WidgetManager, PanelManager, array
2. Add this to your button event listener. (the comment in line 4 is !!!IMPORTANT!!!)
        this.wManager = WidgetManager.getInstance();
        this.pManager = PanelManager.getInstance();
        var widgetCfg = this._getWidgetConfig('Print');
///The above 'Print' need to be swapped for your widgetsname that is in the LDockable panel
        if(widgetCfg) {
          var tWidget = this.wManager.getWidgetByLabel(widgetCfg.label);
          if(tWidget) {
            this.wManager.openWidget(tWidget);
            PanelManager.getInstance().maximizePanel(tWidget.getPanel());
          } else {
            this.wManager.loadWidget(widgetCfg).then(lang.hitch(this, function(widget) {
              if(widget) {
                this.wManager.openWidget(widget);
                PanelManager.getInstance().maximizePanel(widget.getPanel());
3. Add this new helper function to your widget that is opening the LDockable Panel:
      _getWidgetConfig: function(widgetName) {
        var widgetCnfg = null;
        array.some(WidgetManager.getInstance().appConfig.widgetPool.widgets, function(aWidget) {
          if(aWidget.name == widgetName) {
            widgetCnfg = aWidget;
            return true;
          return false;
        if(!widgetCnfg) {
          /*Check OnScreen widgets if not found in widgetPool*/
          array.some(WidgetManager.getInstance().appConfig.widgetOnScreen.widgets, function(aWidget) {
              return true;
            return false;
        if(!widgetCnfg) {
          /*Check OnScreen groups widgets if not found in OnScreen widgets*/
          array.map(WidgetManager.getInstance().appConfig.widgetOnScreen.groups, function(aGroup) {
            array.some(aGroup.widgets, function(aWidget) {
                return true;
              return false;
        return widgetCnfg;
Irfan,
  If you look in my popup panel widget I have code in there to open the LDockable panel from code.
Irfan,
define([
'dojo/_base/array'
        if(widgetCfg) {
          if(tWidget) {
          } else {
              if(widget) {
            return true;
          return false;
        if(!widgetCnfg) {
              return true;
            return false;
        if(!widgetCnfg) {
                return true;
              return false;
        return widgetCnfg;
James_001
Robert,
Great! It is working perfectly. Thanks again for your help!
Irfan Afsar
