Survey123 for update Information SDE
2067
6
08-15-2018 03:10 PM
Arturo_FranciscoAcosta_Bazán
We have implemented ArcGIS Enterprise (Server and Portal -DataStore) Installed .It is possible that you can update the information of our GDB in Oracle from Survey123 connected to Portal for ArcGIS to the teams that work in the field ?
JamesTedrick
Esri Esteemed Contributor
Hi Kamilo,
Archiving is not required for a feature service to be supported by Survey123.  It is enabled through the sync setting, along with the applyEditsWithGlobalIds setting; however, Survey123 only uses the applyEdits setting, not the full Sync workflow.
JamesTedrick
Hi Kamilo,
Yes it is possible to use Survey123 with existing feature services on ArcGIS Enterprise.  Please see
for more information.
Hi James  Do you know of some "step by step" to make the feature layer  (with sufficient conditions : must have a globalid == enable sync when publishing your feature service) to be able to use it in a survey ? . The videos from UC (Ismael) and learning (http://learn.arcgis.com/en/projects/collect-hurricane-damage-assessments/lessons/create-a-feature-la...) already have the feature created.
Thanks.
Tutorial: Configure feature service data for offline use—Documentation | ArcGIS Enterprise , This could help from ArcMap, you just need to know the process from PRO
JamesTedrick
Hi Kamilo,
You should find the steps pretty much identical for ArcGIS Pro- the main difference is that some things that were a right-click in the Catalog window may now be a geoprocessing tool.
James , is necessary  enable archiving  previously in the feature class for my feature service ?
JamesTedrick
Hi Kamilo,
