AnsweredAssumed Answered
How to download feature services with subtypes, domains, attachments and relationships from ArcGIS Online
Question asked by FlorianHuber on Aug 15, 2018
Latest reply on Aug 15, 2018 by andrescastillo08
Hi, I want to download a feature service form ArcGIS Online, which has domains and subtypes jpg attachments as well as relationships between feature classes.
Because of BUG-000084903 my subtypes and domains are lost when I export the service to an file geodatabase. I solved this problem by importing the dataset I download into a empty version of the original dataset. I did this by using the command "Load Objects...". This works to recover the domains and subtypes and also retains the relationships between my feature classes. Unfortunately the attachments are not imported that way. They are listed on the Attachment table but the actual jpg's are not imported.
Alternatively I tried to import the data using the "Append" command. But this way I create new GlobalID's for the imported Data which destroys the relationships (I used the GlobalID as primary key).
Is there any way to keep the original GloablID when using the Append command?
Or does anybody have an idea how else I can import the Data into my original file and retain all the information?
Thank you for your help!
Outcomes
