Can a form have multiple geopoint type location fields?
313
08-14-2018 01:10 PM
SusanMathai
New Contributor III
encountered some errors when used more than once.
JamesTedrick
Esri Esteemed Contributor
Hi Susan,
As Survey123 writes data to an ArcGIS feature service, there are some limitations imposed by feature service capabilities.  One of these is a limitation of one geometry field per layer/table.  This normally leads to a limitation of one point per form.  This can be worked around through a couple of methods:
- Adding a repeat to the form.  Repeats get stored in their own tables and also support up to 1 geometry per repeat section
- Using the esriFieldType of null to display a second (and third, etc.) point, which is not written to the feature service.  The additional points can be referenced by other fields to, for example, store the Lat/Lon of the point as numeric data in the table.  See https://community.esri.com/groups/survey123/blog/2017/10/26/the-power-of-nothing for examples.
