Can I convert from .mmpk to .tpk?
826
08-09-2018 06:13 PM
RogerFarmer1
There are some pretty cool mobile map packages available, can I use it as an offline basemap for a Survey(123) that will be offline for field staff?
There ought to be some cool stuff out there that could be used as an offline map without having to re-invent the wheel!
Roger Farmer
IsmaelChivite
Esri Notable Contributor
Hi. Supporting Mobile Map Packages is in our road map for Survey123.
In the meantime, you can create TPKs from ArcGIS Pro
Jayson Ward
IsmaelChivite
Jayson Ward
ReneAubut
are mmpk now supported for Survey123?
JamesTedrick
Esri Esteemed Contributor
Hi Rene,
MMPKs are not yet supported in Survey123; there has been some preliminary work in this, but is still early enough to not be in beta yet.
