Error using Calculate Accessibility Matrix
384
08-10-2018 05:02 PM
SarahDoggett
I tried to use the Calculate Accessibility Matrix tool but I got Error 000824: The tool is not licensed.
I have Network Analyst, is there another package I need?
DanPatterson_Retired
You don't specify the software or version... so from support...
Error: 000824: The tool is not licensed
000824: The tool is not licensed.—Help | ArcGIS Desktop
In short, make sure that the license is toggled on if working within arcmap or checked out if scripting or you have access to the extension in the first place
SarahDoggett
Thanks! That worked!
MelindaMorang
Did you resolve this problem?
If not, could you copy and paste the full message text so I can take a look (not just the error message, but everything that appears in the geoprocessing window)?
