AnsweredAssumed Answered
Hot Swap maps in WAB?
Question asked by hcarverSABO on Aug 9, 2018
Latest reply on Nov 30, 2018 by rscheitlin
I'm trying to have my WAB setup so that I can change out the underlying maps without doing a lot of changes to WAB widgets.  Essentially I want to reuse the same WAB application with different maps so that the look and functionality are consistent across all the maps.  I built a "Widget" map layer that I add to all the maps to be used by attribute table, etc.  and I set up chart widget with connections to Portal layers instead of map.  However when I try swapping in a new map, the settings are all still there in the chart widget and Search widget but I still have to manually reset the setting to get it to work.  I'm trying to roll out an upgrade to our map series and it would save a lot of time if I could get this to work.
ArcServer w federated Portal 10.3.1, WAB 2.6
Thank You,
Outcomes
