I've created a new domain in a FGDB:
I've created a new field and associated the new domain to it:
But when I go to edit that field I do not see a drop down list with my domain values. All I can do is enter text:
Any idea as to what might be going on??
What happens when you close and restart Pro? There are several bugs related to creating domains in Pro, which yours is similar to:
BUG-000116032 A script is run that creates domains in a feature class, these domains are successfully created. If a second script is run that creates additional domains, these domains won't appear until you close and re launch ArcGIS Pro;
BUG-000115054 ArcGIS Pro does not recognize domains in a SQL Server geodatabase imported from an Extensive Markup Language (XML), until the project is closed and reopened.
