Looking for help to optimize a SQL query in ORACLE. What this does is
Take two polygon layers, overlay/intersect them, and where they intersect, summarize the attributes of the overlay to a aggregate list if the area of intersection is more than 15% of the source poly.
SELECT
hashid,
--this is an aggregate function that sorts and groups overlayed floodzones by parcel
LISTAGG (TO_CHAR (fld_zone), '','') WITHIN GROUP (ORDER BY fld_zone) FLOODZONE
FROM MCGIS.FEMA_2014_FLOOD_ZONES e, parcel.parcels_mv p
WHERE
--get matching polygons
st_intersects (p.shape, e.shape) = 1
AND
--use polygon if more than 15% overlay
(st_area (st_intersection (p.shape, e.shape))) / st_area (p.shape) >.15
--summarize by hashid
GROUP BY hashid
It works perfectly, but takes like 3 hours. i have 30 of these to do every night. Anything i can do to speed it up? Both layers have spatial indexes, and there are attribute indexes on both HASHID and FLD_ZONE fields.
This produces results like
HASHID FLOODZONE
124345 AE,X
124346 X
124347 AE,B,X
instead of
HASHID FLOODZONE
124345 AE
124345 X
124346 X
124347 AE
124347 B
124347 X
My guess on the time would be related to the number of spatial functions that have to run to calculate what is needed.
How many FLOODZONE and PARCEL polys are we talking about?
As for the end result, what if you remove the "GROUP BY hashid" would it give you the output format that you are looking for?
Just as a comparison, have you created a Python script to do the same process and see how long that takes to run?
