Creating Contour Lines with Defense Mapping
429
08-07-2018 01:25 PM
PaulAngell
In the Defense Mapping toolbox, for creating contours it requires a defense mapping feature class.  how do you create the blank feature class required?  The help doc only says a feature layer from an existing Defense Mapping Feature class, but this is the first one I am trying to make, so i don't have an existing one.
Bo_King
Occasional Contributor III
Hi Paul
Thanks for your question.  The Create Contours tool was designed to generate features for the products supported in Esri Defense Mapping.  For example, if you are building a Topographic Map (TM) using TDS data, you would use the HypsographyCurves feature class found in the TDS database schema.
The TDS database can be found in the installed product files:
      <install directory>\ArcGIS\EsriDefenseMapping\Desktop10.6\Tds\Schema
If you have additional questions, reply here, or post them to the Esri Defense Mapping page.  Thanks.
Regards,
Bo
defense mapping‌
esri defense mapping‌
