Bloody Windows Graphics Card Block
981
08-05-2018 12:13 PM
warrenroberts
Occasional Contributor II
Ugh.  "Application has been blocked from accessing Graphics Hardware" .. blocking ArcGIS Pro .. anyone else have same issue and know a fix for this?  Thanks all!! 🙂
DanPatterson_Retired
Yes... just can't put my finger on the thread.
Solutions...
Of course you might want to elaborate on what you were doing that led to this
Robert_LeClair
Esri Notable Contributor
Another user was experiencing this same issue and resolved it using the following steps - "Went into the Displays option with ArcGIS Pro and deleted the cache, changed Antialiasing mode to Best, Stereoscopic mode to off and checked the Enable hardware antialiasing option."
Hope this helps!
And to follow up with Robert's suggestion
How caching works—ArcGIS Pro | ArcGIS Desktop
I never cache, but I have no need to
MervynLotter
Occasional Contributor III
More than a year ago I encountered a similar problem and had to uninstall my display driver and then reinstall the driver from manufacturer. If you google this error message there are many suggestions on how to go about fixing it, I followed some of these and I ended up running a 3rd party app to uninstall display driver.
