Tools for regularization of polygons- the mean error of the position of the points
745
08-04-2018 11:48 AM
MalgorzataMendela
New Contributor III
Is it possible to regularize polygons in ArcGIS based on the mean error of the position of the points, which is one of the parameters of a tool in ArcGIS?
I know that Regularize Building Footprint is a tool, which can be used to regularize polygons representing buildings, but a user probably can not set there a value for the mean error of the position of the points as a parameter.
Do you know if I can use another tool in ArcGIS which allows for setting as a starting parametr the above mentioned value?
DanPatterson_Retired
For people not aware of the tool
Regularize Building Footprint—Help | ArcGIS Desktop
and there are not other listed methods in this toolset meaning it would have to be coded.
Numpy, scipy and other modules could perhaps be used if you have an algorithm to implement
MalgorzataMendela
New Contributor III
Hello Dan,
thank you for reply.
Do you know if ArcGIS has a tool which uses for computations a robust method for adjustment of polygons or a user has to build an appropriate script?
None that I can find.  I don't know what algorithm you might be referring to
