Have a survey that has 20 groups with a total of 69 questions spread out over the groups. Each question is answered by a yes-no-n/a select one. Each question has corresponding "Text" and "Image" field types with a relevant statement: ${name} does not equal "Yes".
Is there a way to reduce the number of "Text" and "Image" fields? Because I am having difficulty utilizing the Beta Print function due to the number of NULL fields associated with the survey.
I grouped the questions because it was overwhelming in the field to look at...
Hi Oscar,
When you ask "Is there a way to reduce the number of "Text" and "Image" fields?" what are you referring to, where do you want to reduce the number of fields, do you mean in the custom report template or in your xlsx form design?
Phil.
