ruben.perezesri-es-esridist
PKIX Exception in Portal using Utility services
Discussion created by ruben.perezesri-es-esridist Employee on Aug 1, 2018
Latest reply on Aug 23, 2018 by ruben.perezesri-es-esridist
I have implemented a fully ArcGIS Enterprise Base Deployment (only https with a valid certificate in IIS). I have configured it to use ArcGIS  utility services, embedding an arcGIS  valid user.
But, when I try to use it (for example create a buffer around point features in the map viewer) an exception arise:
"Create Service exception ' Exception: sun.security.validator.ValidatorException: PKIX path building failed: host unable to find valid certification path to requested target'"
I know this is about SSL certificates and I add some certificates to portal repository (portal/portaladmin/security/sslCertificates/) including the IIS certificate and ArcGIS  certificate (I'm desperate...  )
What I have to do to fix this??
thanks!!!
Outcomes
