How to display InfoTemplate in a separate window instead of popup
766
07-30-2018 10:05 AM
NageshC
I have defined a InfoTemplate as follows and added it to a CSV Layer
var CabinetTemplate = new esri.InfoTemplate();
CabinetTemplate.setTitle("<b> ${type}</b>");
CabinetTemplate.setContent("${description} <br\> ${latitude},${longitude} ");
CabinetCSVLayer.setInfoTemplate(CabinetTemplate);
It is working fine as a popup.
But I want to display this InfoTemplate in a separate window.
Could anyone please let me know how can I get this InfoTemplate in a separate window.
JeffBigos
Hi Nagesh,
Take a look at the following samples from the API, they will illustrate different ways to accomplish what you are looking for.
3.X api:
         Popup content in side panel | ArcGIS API for JavaScript 3.25
4.x api:
         Popup with DOM node | ArcGIS API for JavaScript 4.8
Let me know if this is what you were looking for.
Jeff
NageshC
Hello Jeff,
Thanks for your message.
I have seen the given links and they show how to display the popup in a side panel or DOM node.
But my requirement is different.
I want to display the info in a separate window so that I can move it to a different screen leaving the map as is.
Please let me know if you have any solution for this.
Nagesh
