AnsweredAssumed Answered
ArcGIS Pro 2.2 - REVIT Files with families from plugins
Question asked by nick.moore on Jul 19, 2018
Latest reply on Jul 22, 2018 by nick.moore
Hi There,
We have been testing the new functionality with ArcGIS Pro 2.2 and have found that it does not read all Revit files even though they are in 2018 format. Does ArcGIS Pro only read "standard" families and what are the limitations there?
Any revit file that has MEP Fabrication Pipework Families will not open in pro. These are created using the Autodesk Fabrication Piping Plugin. This would also mean that Fabrication Ducting and HVAC systems created through the same plugin will not actually work.
When i open the Revit file, remove these pipes and fittings from the model it opens fine.
The error thrown by Pro is as Follows: "External Component has thrown an Exception" No Error Code.
Any help would be much appreciated?
Outcomes
