We have two new Windows 10 Panasonic Toughpads running GNSS Status App (v3.0.0.327) connected to two new Trimble R2 (v5.35) with real-time corrections. In Collector (v18.0.1.0) we can see the accuracy readout showing up to 7cm. Yet the Submit is not available and the heading in the create feature box says Unknown Location. We've tried basic feature layers (editable, sharable) on basic maps. This problem is intermittent and does work on rare occasions but usually does not work. We have 20+ satellites, NTRIP corrections in open skies etc. Location Profile is Default. GNSS Status app displays appropriate NMEA Sentences.
I've tested the exact same setup concurently in iOS and everything works fine. How is Collector different in Windows10 vs. iOS?
Attached are screenshots.
Anything you can offer is appreciated!
Tim
For the Trimble R2 receiver on Windows, Collector can't access locations with RTX or local base station corrected locations via NTRIP. Collector can only access autonomous GPS fixes and SBAS corrected locations.
GPS receiver support—Collector for ArcGIS | ArcGIS
