polyline validation in circle
584
07-19-2018 10:24 AM
MRReddy
polyline shouldn't cross the circle boundary, how to verify does polyline came outside from circle(which is drawn on basis of center point with 1/4 radius).
100 % of polyline should be inside/touch the circle, not outside.
got stuck, Any help would be appreciated
KenBuja
MVP Esteemed Contributor
You can use various methods in the geometryEngine class.
  • contains will check whether the polyline is inside the circle
  • intersects will check if they cross each other
  • touches will check if they touch each other
  • disjoint will check if they don't intersect at all
KenBuja
