Can't deploy custom WAB application to web server
653
07-19-2018 06:07 AM
joerodmey
Trying to deploy my web app from WAB to my own web server but app hangs on the loading screen (screenshot attached). This is also the case when I try running the app locally when I fire up the the index.html. It's worked in the past.
What may be causing this issue?
JoseBanuelos
Joe,
From the screenshot, it looks like you are trying to access the application from the server > apps folder. In order to properly deploy it, you need to download the zip file of the application from your Web AppBuilder's home page, unzip it, and move it to your web server.
Here is a link to a thread that explains the steps in great detail.
https://community.esri.com/thread/161776
Accessing the application from the server > apps folder path results in a loading screen that does not complete.
-Jose
JoseBanuelos
Joe,
-Jose
joerodmey
Thanks it worked
