About displaying Electronic Navigational Charts
704
07-18-2018 06:55 PM
sd3
Hello, we are trying to create an app that show our local *.000 sea map file with Android Studio. We wrote some codes like the tutorial  here for displaying ENC. But they aren't working. Could you help us? Where exactly did we wrong or could you send us a code?
So here our codes in MainActivity:
package com.example.slm.mapvw;
import android.os.Environment;
import android.os.StrictMode;
import android.support.v7.app.AppCompatActivity;
import android.os.Bundle;
import com.esri.arcgisruntime.hydrography.EncCell;
import com.esri.arcgisruntime.hydrography.EncDataset;
import com.esri.arcgisruntime.hydrography.EncEnvironmentSettings;
import com.esri.arcgisruntime.hydrography.EncExchangeSet;
import com.esri.arcgisruntime.layers.EncLayer;
import com.esri.arcgisruntime.mapping.view.MapView;
import com.esri.arcgisruntime.mapping.ArcGISMap;
import java.util.ArrayList;
import java.util.Arrays;
public class MainActivity extends AppCompatActivity {
    public MapView mMapView;
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        mMapView = findViewById(R.id.mapView);
        ArcGISMap map = new ArcGISMap();
        EncEnvironmentSettings.setResourcePath("file:///android_asset/hydrography/");
        EncEnvironmentSettings.setSencDataPath("file:///android_asset/sencDataPath/");
        EncExchangeSet encExchangeSet =
                new EncExchangeSet(new ArrayList<>(Arrays.asList("file:///android_asset/ENC_ROOT/CATALOG.031")));
        encExchangeSet.loadAsync();
        encExchangeSet.addDoneLoadingListener(() -> {
            for (EncDataset encDataset : encExchangeSet.getDatasets()) {
                EncLayer encLayer = new EncLayer(new EncCell(encDataset));
                map.getOperationalLayers().add(encLayer);
        mMapView.setMap(map);
        EncEnvironmentSettings.getDisplaySettings().getTextGroupVisibilitySettings().setIsNatureOfSeabed(true);
    @Override
    protected void onPause(){
        mMapView.pause();
        super.onPause();
    @Override
    protected void onResume(){
        super.onResume();
        mMapView.resume();
    @Override
    protected void onDestroy() {
        super.onDestroy();
        mMapView.dispose();
I'm using those permisions in AndroidManifest.xml
<uses-permission android:name="android.permission.INTERNET" />
<uses-permission android:name="android.permission.WRITE_EXTERNAL_STORAGE" />
<uses-permission android:name="android.permission.ACCESS_FINE_LOCATION" />
<uses-permission android:name="android.permission.READ_EXTERNAL_STORAGE" />
And also our build.gradle's and resource folders:
Thank you in advance!
sd3
Nobody knows?
sd3
Still searching about that
RamaChintapalli
Can you try copying the data to the external storage directory.
You can get access your external storage in the app using
Environment.getExternalStorageDirectory()
Environment  |  Android Developers
Rama
