Pro 2.2 Missing Network drives
783
07-17-2018 11:59 AM
RyanTucker1
Just as the title says I am missing my network drives when I go to open existing projects that were created on network drives. Pro says "Project not found".  Anyone else having this issue? Or is this some expected behavior from Pro?
I can get to the projects by typing in the UNC file path in the open project dialog, but that's going to be ridiculous for all my projects.
ThomasColson
MVP Frequent Contributor
You're gonna hate this, but this is what TS is going to have you do.....Did you reboot, and same problem? After rebooting, create a new Pro project on a network drive, close Pro. Same issue? Are you starting Pro from a template? Same issue if you start Pro using Blank Template? Are you able to add folder connections to those network drives?
RyanTucker1
Thanks for the reply.
Yes I've rebooted, multiple times. Same issue.
I just tried to create a blank project. When I go to Select a folder to store project, same issue, no network drives to choose from...I see my C drive and an External drive I just plugged in though.
RyanTucker1
I fixed my issue by unchecking run as administrator.
