AnsweredAssumed Answered
Custom parameters with WFS services (LINZ) ?
Question asked by GeoShimaNZ3 on Jul 16, 2018
I have been trying to use a public WFS service NZ Street Address Web Services and API Availability | LINZ Data Service .
My main objective is to display some point of this service on my WAB developer edition, based on bounding box using Javascript.
I have achieve to display the data on my map but the custom parameters seems completely ignored.
Here is the link from LINZ which provide a parameter to set a bounding box. https://www.linz.govt.nz/data/linz-data-service/guides-and-documentation/wfs-spatial-filtering
If i only use my browser the custom parameter from LINZ works perfectly :
http://data.linz.govt.nz/services;key="the key that you can generate easily on the linz website"/wfs?service=WFS&version=2.0.0&request=GetFeature&typeNames=layer-53353&cql_filter=bbox(shape,42.436793,173.634652,-42.384224,173.727006)
I also have tried to add this custom parameter "cql_filter=bbox(shape,42.436793,173.634652,-42.384224,173.727006) " in Arcgis Online map viewer too (when added "layer from web" -> "WFS OGC  web service") but it's ignored so the output data are not limited by this bounding box.
I have been stuck on this problem for  a while now, please if someone has a solution or has already done something similar your help will be much appreciated.
My JS looks like this :
esriConfig.defaults.io.corsEnabledServers.push("data.linz.govt.nz"); // supports CORS
var url = "https://data.linz.govt.nz/services;key="the key that you can generate easily on linz website"/wfs?REQUEST=GetFeature&typeNames=layer-53353&BBOX(shape,-36.764156,174.975230,-36.817467,175.023120)";
var opts = {
     customParameters : {"cql_filter":"bbox(shape,-36.764156,174.975230,-36.817467,175.023120)"},
     url: url,
     version: "2.0.0",
     wkid: 4326,
     maxFeatures: 1000
var mylayer = new WFSLayer();
mylayer.fromJson(opts);
var symbol = new SimpleMarkerSymbol().setColor(new esri.Color([255,0,0,0.5]));
var renderer = new SimpleRenderer(symbol);
mylayer.setRenderer(renderer);
this.map.addLayer(mylayer);
Outcomes
