ArcGIS Map Search for SharePoint Online
615
07-16-2018 04:14 AM
NickFosbery
Has anyone had any luck getting the new ArcGIS Map Search for SharePoint running when using SharePoint Online(Office 365)?
I seem to be able to configure it OK and create the term store index, but when it comes to adding the Map Search part in a page it appears to start loading but will eventually hang with just a circular 'loading' icon in the middle of the screen.  The last error message that comes out on the IE console is as follows:
Mon Jul 16 2018 12:05:55 GMT+0100 (GMT Summer Time):RequestExecutor.OnMessage: Message.data={"command":"Query","postMessageId":"SP.RequestExecutor1","responseAvailable":false,"errorCode":-1005,"errorMessage":"There is no trusted URLs configured for the app deployment."}
In the app details/settings I can 're-trust' the app but it doesn't seem to make any difference.
The normal map works fine.
Any suggestions much appreciated!##
WillHughes2
New Contributor III
Are you adding the App Part or Web Part? You should be using the App Part in version 5.0.  You might try re-installing the application. If that doesn't fix it then submit a case with Esri Tech Support.
