Balcony placement and turn on/off attribute
450
07-15-2018 06:36 AM
DarioCvitkusic
i have two simple cga questions.
how i can place more balconies directly under the 1floor windows and add a enabled/diabled attribute for them?
regards
Dario
LR
Occasional Contributor III
You add a reference to a balcony rule in the same bit that references the window generation and use a case to control its generation, like this:
attr BalconyEnabled = true
Lot -->
   Window
   Balcony
Window -->
Balcony -->
   case BalconyEnabled == true: RuleForBalconyCreation
   else: NIL‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
RuleForBalconyCreation -->
DarioCvitkusic
Thank you, for the balcony the switch works fine but fot the details such as the red top ornament it wont. it just disapeared with this rule..
attr OrnamentTopEnabled = true
WindowOrnamentTop -->
case OrnamentTopEnabled == true: WindowOrnamentTop
s('1.2, 0.4, 0.3) center(x)
i(ornament1)
color("#ff0000")
else: NIL
LR
That rule calls itself when the case is true, infinitely.
