Animate from one view to other
596
07-12-2018 02:39 PM
RezaNikfal
I've just tried to animate from first view to the second as follows:
<!DOCTYPE html>
<html>
<head>
    <meta charset="utf-8">
    <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
    <title>Popup actions - 4.8</title>
    <style>
        html,
        body,
        #viewDiv {
            padding: 0;
            margin: 0;
            height: 100%;
            width: 100%;
    </style>
    <link rel="stylesheet" href="https://js.arcgis.com/4.8/esri/css/main.css">
    <script src="https://js.arcgis.com/4.8/"></script>
    <script>
        require([
            "esri/Map",
            "esri/views/MapView",
            "esri/geometry/Extent",
            "esri/geometry/Point",
            "dojo/domReady!"
        ], function (
            Map,
            MapView,
            Extent,
            Point
                // Create the Map
                const map = new Map({
                    basemap: "topo"
                // Create the Constrains
                const constraints = new Object({
                    minScale: 1000000,  // User cannot zoom out beyond a scale of 1:500,000
                    maxScale: 0,  // User can overzoom tiles
                    snapToZoom: false,
                // Center of the Map
                const point = new Point({
                    x: -96.8236,
                    y: 33.1507
                // Create the Extent
                const extent = new Extent({
                    xmin: -9177882,
                    ymin: 4246761,
                    xmax: -9176720,
                    ymax: 4247967,
                    spatialReference: {
                        wkid: 102100
                // Create the MapView
                const view = new MapView({
                    container: "viewDiv",
                    map: map,
                    zoom: 12,
                    extent: extent
                view.when(function () {
                        view.goTo({
                            target: point,
                            zoom: 12
                    }, function (error) {
                        console.log("Error no." + error + "Happend");
    </script>
</head>
<body>
    <div id="viewDiv"></div>
</body>
</html>
bu it just shows the second view. Any solution?
RobertScheitlin__GISP
Reza,
    The view.then will return before the view is actually drawn so you will execute the goto before the view has drawn initially. You can see this by adding a setTimeout like have bellow.
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
      "esri/Map",
      "dojo/domReady!"
    ], function(
      Map,
      MapView,
      Extent,
      Point
      // Create the Map
        basemap: "topo"
        snapToZoom: false,
        x: -96.8236,
        y: 33.1507
        xmin: -9177882,
        ymin: 4246761,
        xmax: -9176720,
        ymax: 4247967,
        spatialReference: {
          wkid: 102100
        map: map,
        zoom: 12,
        extent: extent
      view.when(function() {
        setTimeout(function(){
          view.goTo({
            target: point,
            zoom: 12
        }, 5000)
      }, function(error) {
  </script>
</head>
<body>
</body>
</html>
RezaNikfal
Robert,
I am trying to animate the movement from the first view to the next like this Esri's sample on scene view.
Reza,
   You are not going to get a MapView to animate the same way the SceneView does. The issue is they way they attempt to retrieve the cached map is completely different.
MohammadrezaNikfal1
Agree, the updating process in Map View during animation does not work like Scene View. In other words, the goto() works as expected and the issue is the animation process itself. During this process, the image tiles are not updated. So when you animate a large scale map view in a short distance (according to scale), you can get an animation. Otherwise, during animation you get a white screen.
Take a look at the following code that creates animation in Map view:
<!DOCTYPE html>
<html>
<head>
    <style>
        html,
        body,
        #viewDiv {
            padding: 0;
            margin: 0;
            height: 100%;
            width: 100%;
    </style>
    <script>
        require([
            "esri/Map",
            "dojo/domReady!"
        ], function (
            Map,
            MapView,
            Point,
            var map = new Map({
                basemap: "streets"
                x: -96.8236,
                y: 33.1507
            const point1 = new Point({
                x: -95.6236,
                y: 33.5507
            var view = new MapView({
                map: map,
                zoom: 8,
                center: point
                view.goTo({
                    center: point1,
                    zoom: 8
                    { duration: 4000, easing: "linear " }
    </script>
</head>
<body>
</body>
</html>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
If you increase the Zoom to 14 or duration to 400 you do not get a good animation.
