AnsweredAssumed Answered
GPS track points to "bivariate" polygons
Question asked by WarrenDz on Jul 12, 2018
Latest reply on Mar 28, 2019 by WarrenDz
I thought it would be really cool to symbolize data from GPS tracks as a tapered line/polygon based on their attributes (I've set my sights on polygon geometry so I could eventually fill said polygons with a gradient fill thereby tying them together). I imagine this to look slighty accordian in nature with fluctuating polygon width as an attribute such as speed changes along some track (see concept image below). It's conceptually similar to the 'Tapered Line' symbol effect in ArcGIS Pro but allows for the ability to fill the polygon and vary the taper by attribute. This would allow me to do some of the data visualisation that would typically occur in graphic design software.
Concept image of the "stretched" polygons I'm looking to create.
As it stands, the code I've written to achieve this 'nearly' work which is why I'm posting here. I've been able to create the polygons, and modify the taper but there are two main issues I've identified.
The results of the script so far...
  1. The taper doesn't seem to always respect the attribute value that determines the width (note data points that have speed label of 17 - Center left of image, are more narrow than those that are 10, 11, 12 - Upper left of image). I suspect somethign is wonky with my equations where I calculate the offsets used to "stretch" the polygon width.
  2.  In addition, for a reason that I cannot pin down, there are some polygons that get turned into "bowties" and become multi-part polygons when they should be quadrilaterals (from troubleshooting it seems like my Insert cursor inserted the 4th coordinate pair before the 3rd?)
If anyone has some tips, suggestions, thoughts, or if this code already exists somewhere. I'd be more than grateful to listen and learn.
Warren
Here's my code as it stands now, I've written it to run from a script tool in ArcGIS Pro (I've also attached the script and toolbox).
# Move bank data source (albatross GPS tracks)
# Dodge S, Bohrer G, Weinzierl R, Davidson SC, Kays R, Douglas D, Cruz S, Han J, Brandes D, Wikelski M (2013)
# The Environmental-Data Automated Track Annotation (Env-DATA) System—linking animal tracks with environmental data.
# Movement Ecology 1:3. doi:10.1186/2051-3933-1-3
# Cruz S, Proaño CB, Anderson D, Huyvaert K, Wikelski M (2013) Data from:
# System: Linking animal tracks with environmental data. Movebank Data Repository. doi:10.5441/001/1.3hp3s250
# imports
import arcpy
from math import sqrt
import sys
from math import cos
# overwrite the outputs
# Get parameters from dialog
# input points
source_points = arcpy.GetParameterAsText(0)
# variable parameters
primary_param = arcpy.GetParameterAsText(1)  # Parameter to classify and use to "stretch" geometry width
secondary_param = arcpy.GetParameterAsText(2)  # Parameter that we'll carry over for symbology purposes
num_breaks = arcpy.GetParameterAsText(3)  # Number of classes to break the primary attribute values into
min_width = arcpy.GetParameterAsText(4)  # minimum width (metres) that a polygon should be at an end
max_width = arcpy.GetParameterAsText(5)  # maximum width (metres) that a polygon should be at an end
break_dictionary = {}
# output polygons
output_polygons = arcpy.GetParameterAsText(6)  # output location file gdb
def msg(text):
    arcpy.AddMessage(text)
    print(text)
def width_factor(attribute_value, dictionary):
    for k, v in dictionary.items():
        if attribute_value <= dictionary[k][0]:
            attribute = k
            break
        else:
            attribute = num_breaks
    msg('assigned: {0}'.format(attribute))
    return attribute
def offset_calc(distance, plane, latitude):
    # https://gis.stackexchange.com/questions/2951/algorithm-for-offsetting-a-latitude-longitude-by-some-amount-of-meters
    if plane == 'y':
        offset = float(distance)/111111
        offset /= 2
    else:
        offset = float(distance)/(111111 * cos(latitude))
        offset /= 2
    return offset
# Understand Attribute Parameter
msg('Understanding attribute parameter...')
value_list = []
with arcpy.da.SearchCursor(in_table=source_points, field_names=primary_param) as parameter_cursor:
    msg('Scanning attribute values...')
    for row in parameter_cursor:
        value_list.append(row[0])
msg('Scan complete.\n\n')
# Assign min/max values
min_attribute = min(value_list)
max_attribute = max(value_list)
msg('Minimum and maximum values assigned: Min({0}), Max({1})'.format(min_attribute, max_attribute))
range_attribute = max_attribute - min_attribute
msg('Range identified: {0}'.format(range_attribute))
step = range_attribute/float(num_breaks)
msg('Range step identified: {0}\n'.format(step))
# Assign polygon width values
width_range = float(max_width) - float(min_width)
width_step = width_range/float(num_breaks)
msg('Assigned width step: {0}'.format(width_step))
# Create dictionary of break values [attribute, width]
for i in range(1, int(num_breaks)+1, 1):
    break_value = i * step + min_attribute
    width_value = i * width_step + float(min_width)
    break_dictionary[i] = [break_value, width_value]
    msg('Assigned dictionary break value {0}: {1}'.format(i, break_dictionary[i]))
msg(break_dictionary)
# Create output feature class
workspace_index = output_polygons.rfind('\\')
workspace = output_polygons[:workspace_index]
output_name = output_polygons[workspace_index + 1:]
# Set spatial reference to match input
sr = arcpy.Describe(source_points).spatialReference
msg(str(sr))
msg('Creating "{0}" feature class to store outputs.'.format(output_name))
arcpy.CreateFeatureclass_management(out_path=workspace, out_name=output_name, geometry_type="POLYGON", spatial_reference=sr)
# Add schema
msg('Adding standard fields.')
# Need to have field type detection eventually
arcpy.AddFields_management(in_table=output_polygons, field_description=[
    ['LINE_FID', 'SHORT'],
    ['PRIMARY_VALUE', 'DOUBLE'],
    ['PRIMARY_CLASSED', 'SHORT'],
    ['SECONDARY_VALUE', 'DOUBLE'],
msg('Output feature class created.')
# Open search cursor on points in order to gather geometry
index = 0
feature_dictionary = {}
with arcpy.da.SearchCursor(in_table=source_points, field_names=['OBJECTID', primary_param, secondary_param, 'SHAPE@X', 'SHAPE@Y']) as s_cursor:
    for row in s_cursor:
        feature_dictionary[index] = [row[0], row[1], row[2], row[3], row[4]]
        index += 1
msg('Point features consumed.')
# msg(str(feature_dictionary))
# Puke up features from dictionary
# msg('LAST ITEM: {0}'.format(list(feature_dictionary.keys())[-1]))
with arcpy.da.InsertCursor(in_table=output_polygons, field_names=['LINE_FID', 'PRIMARY_VALUE', 'PRIMARY_CLASSED', 'SECONDARY_VALUE', 'SHAPE@']) as i_cursor:
    for key, value in feature_dictionary.items():
        msg('KEY: {0}, INDEX: {1}'.format(key, index))
        if key == 0:
            msg('Process as first point (triangle)')
            pass
        elif index == int(key + 2):
            msg('Process as second last point (triangle)')
            pass
        elif index == int(key + 1):
            msg('Process as last point, therefore skip')
            pass
        else:
            msg('Processing as normal point')
            # https://stackoverflow.com/questions/133897/how-do-you-find-a-point-at-a-given-perpendicular-distance-from-a-line
            # msg(str(feature_dictionary[key]))
            # Process as usual
            # POINT 1
            # Get difference of x between prior point and subsequent
            # dx = x1 - x2
            dx = float(feature_dictionary[key-1][3]) - float(feature_dictionary[key+1][3])
            # Get difference of y between prior point and subsequent
            # dy = y1 - y2
            dy = float(feature_dictionary[key-1][4]) - float(feature_dictionary[key+1][4])
            # dist = sqrt(dx*dx + dy*dy)
            dist = sqrt(dx * dx + dy * dy)
            # Reassign dx and dy
            if dx > 0:
                dx /= dist
            else:
                dx = dx
            if dy > 0:
                dy /= dist
            else:
                dy = dy
            # Get coordinates for starting vertices (counter-clockwise starting top left)
            # x3 = x1 + (N/2)*dy
            # FACTORED
            # Bookmark primary attribute value
            wf = width_factor(feature_dictionary[key][1], break_dictionary)
            msg('WF: {0}'.format(wf))
            # Bookmark break value
            bv = break_dictionary[wf][1]
            msg('BV: {0}'.format(bv))
            x1 = float(feature_dictionary[key][3]) + offset_calc(float(bv), 'x', feature_dictionary[key][4]) * dy
            y1 = float(feature_dictionary[key][4]) - offset_calc(float(bv), 'x', feature_dictionary[key][4]) * dx
            x2 = float(feature_dictionary[key][3]) - offset_calc(float(bv), 'x', feature_dictionary[key][4]) * dy
            y2 = float(feature_dictionary[key][4]) + offset_calc(float(bv), 'x', feature_dictionary[key][4]) * dx
            dx2 = float(feature_dictionary[key][3]) - float(feature_dictionary[key+2][3])
            dy2 = float(feature_dictionary[key][4]) - float(feature_dictionary[key+2][4])
            dist2 = sqrt(dx2 * dx2 + dy2 * dy2)
            if dx2 > 0:
                dx2 /= dist2
            else:
                dx2 = dx2
            if dy2 > 0:
                dy2 /= dist2
            else:
                dy2 = dy2
            # Get coordinates for second pair
            # FACTORED
            wf = width_factor(feature_dictionary[key+1][1], break_dictionary)
            msg('WF2: {0}'.format(wf))
            msg('BV2: {0}'.format(bv))
            x3 = float(feature_dictionary[key+1][3]) + offset_calc(float(bv), 'x', feature_dictionary[key+1][4]) * dy2
            y3 = float(feature_dictionary[key+1][4]) - offset_calc(float(bv), 'x', feature_dictionary[key+1][4]) * dx2
            x4 = float(feature_dictionary[key+1][3]) - offset_calc(float(bv), 'x', feature_dictionary[key+1][4]) * dy2
            y4 = float(feature_dictionary[key+1][4]) + offset_calc(float(bv), 'x', feature_dictionary[key+1][4]) * dx2
            # Create feature
            coordinates = [(float(x1), float(y1)), (float(x2), float(y2)), (float(x4), float(y4)), (float(x3), float(y3))]
            try:
                msg('Attempting insert')
                # 'OBJECTID', primary_param, secondary_param, 'SHAPE@X', 'SHAPE@Y'
                # 'LINE_FID', 'PRIMARY_VALUE', 'PRIMARY_CLASSED', 'SECONDARY_VALUE', 'SHAPE@'
                data = [feature_dictionary[key][0], feature_dictionary[key][1], width_factor(feature_dictionary[key][1], break_dictionary), feature_dictionary[key][2], coordinates]
                msg(data)
                i_cursor.insertRow(data)
            except:
                e = sys.exc_info()[1]
                msg('Insert failed: {0}'.format(e.args[0]))
Outcomes
